Starter Relocation Kit For a Lakewood Bellhousing
#1073315
09/11/11 08:07 PM
09/11/11 08:07 PM
Posts: 768 Maryville tn
67coronetman
Maryville tn
Can anyone give me real valuable info on how to best use & install the starter relocation kit cause i really am not understanding.! Or did someone out here find a way to make it work with out it.!
Old car are me......
Re: Starter Relocation Kit For a Lakewood Bellhousing
[Re: 67coronetman]
#1073316
09/12/11 08:10 PM
09/12/11 08:10 PM
67coronetman
Maryville tn
I would really appreciate it if someone has some info & yes i have looked at lakewood bellhousing site.!
[Re: Bill MeLater]
#1073319
09/12/11 10:24 PM
09/12/11 10:24 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
If you're talking about the cup/bolt that captures the starter nose it's just a matter of bolting it in the innermost hole for a 130 tooth flywheel, outer hole for a 143 tooth wheel. If that's not what you're describing...Dunno?
Isn't there also a piece that bolts to the bell that grabs a starter bolt to hold the starter in the correct location along with the nose cup ?
[Re: Bill MeLater]
#1073321
09/12/11 11:43 PM
09/12/11 11:43 PM
67coronetman
Maryville tn
Thanks for the replies i looked at my bellhousing and its the wrong one that is why it didn't work! i have the right bellhousing coming. Quote:
Mine just has a single top bolt location and 2 on the bottom for locating the starter to match the flywheel. Can't say for sure that's the only way they ever made 'em??
[Re: JohnRR]
#1073322
09/13/11 03:49 AM
09/13/11 03:49 AM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
Yes, I had to use it on my lower starter bolt....440 with 130 tooth.(correction = not 143)
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: JohnRR]
#1073323
09/14/11 04:21 PM
09/14/11 04:21 PM
Posts: 2,734 Charlotte, NC
446acuda
Charlotte, NC
there is and used with 130T only. here's a pic
[Re: 446acuda]
#1073327
09/14/11 05:58 PM
09/14/11 05:58 PM
fury4speed
So the adapter is used with a 130 Tooth Flywheel only if your using a scatter shield? thanks.
