Re: Will this pass tech
[Re: HotRodDave]
#1073152
09/11/11 03:26 PM
09/11/11 03:26 PM
Posts: 115 NY,Poughkeepsie
87MO DAK
NY,Poughkeepsie
If I was a tech guy I would pass the fuel lines but not the FRAM oil filter
Its an HP1 ..Im going to change it ,but what is good? I can get a WIX cheap. Thanks
[Re: DoubleD]
#1073154
09/11/11 04:43 PM
09/11/11 04:43 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
probably will pass - but unless you like under hood fires that regulator should be firmly mounted. That's a bunch a weight hanging off an aluminum thin wall pipe - be safe and mount it right.
it will pass but dude take 10 minutes and make a bracket for it.
[Re: sam64]
#1073156
09/11/11 04:59 PM
09/11/11 04:59 PM
Mr.Yuck
Brookeville, Md
chuck nuytten carbs says regulators should not be hard mounted,of course he was telling me thats why the complete fuel system and carb that i got from him speced to my engine wouldn't work right.said vibration from being mounted won't let regulator work right.it didn't cure the problem i was having,ended up selling that carb and put mine back on.
What? Never heard of such a thing. I've never seen on "floating" w/o a mount...except for the OP's.
[Re: 87MO DAK]
#1073159
09/11/11 08:39 PM
09/11/11 08:39 PM
Posts: 7,506 Az
Crizila
Az
This is what you need to do - but it probably will pass - but not without comment.
Fastest 300
[Re: 87MO DAK]
#1073162
09/11/11 10:07 PM
09/11/11 10:07 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
WIX 51515R
Rickster
[Re: 87MO DAK]
#1073166
09/13/11 02:25 PM
09/13/11 02:25 PM
Posts: 2,273 Greenville, South Carolina
BBLM23
I have one of those brackets that goes under the carb to hold the regulator on the side of the carb sitting in the basement. I think what you have will be fine.
Walter 1969 Dart Swinger w/ARC Pump Gas 493 B1/BS 10.18 at 130mph Racing Pro in street trim. 1981 Aries ARC 548 B1 8.88 at 147mph (footbraking) 1996 Ram 2500 V10 16.52 at 80mph 1981 Reliant 400
[Re: 87MO DAK]
#1073168
09/13/11 07:18 PM
09/13/11 07:18 PM
Posts: 1,572 wisconSIN
Blown61
wisconSIN
I decided to make a bracket... Thanks for the input.
You do know that those regs only have a .25 dia opening in them? all those big hoses aren't doing much.
