Will this pass tech #1073149
09/11/11 03:22 PM
09/11/11 03:22 PM
NY,Poughkeepsie
87MO DAK Offline OP
87MO DAK  Offline OP
NY,Poughkeepsie
Last time to the track ,I had to move the fuel regulator...
So with what i had on hand this is what I could do .
Will it pass?
Re: Will this pass tech [Re: 87MO DAK] #1073150
09/11/11 03:23 PM
09/11/11 03:23 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
If I was a tech guy I would pass the fuel lines but not the FRAM oil filter
Re: Will this pass tech [Re: 87MO DAK] #1073151
09/11/11 03:24 PM
09/11/11 03:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I would say yes it will
Re: Will this pass tech [Re: HotRodDave] #1073152
09/11/11 03:26 PM
09/11/11 03:26 PM
NY,Poughkeepsie
87MO DAK Offline OP
87MO DAK  Offline OP
NY,Poughkeepsie
Its an HP1 ..Im going to change it ,but what is good? I can get a WIX cheap.
Re: Will this pass tech [Re: 87MO DAK] #1073153
09/11/11 04:05 PM
09/11/11 04:05 PM
NE Ohio
DoubleD Online content
DoubleD  Online Content
NE Ohio
probably will pass - but unless you like under hood fires that regulator should be firmly mounted. That's a bunch a weight hanging off an aluminum thin wall pipe - be safe and mount it right.
Re: Will this pass tech [Re: DoubleD] #1073154
09/11/11 04:43 PM
09/11/11 04:43 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
it will pass but dude take 10 minutes and make a bracket for it.
Coming soon!!!!
Re: Will this pass tech [Re: DoubleD] #1073155
09/11/11 04:46 PM
09/11/11 04:46 PM
okla.
sam64 Offline
sam64  Offline
okla.
chuck nuytten carbs says regulators should not be hard mounted,of course he was telling me thats why the complete fuel system and carb that i got from him speced to my engine wouldn't work right.said vibration from being mounted won't let regulator work right.it didn't cure the problem i was having,ended up selling that carb and put mine back on.
Re: Will this pass tech [Re: sam64] #1073156
09/11/11 04:59 PM
09/11/11 04:59 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
What? Never heard of such a thing. I've never seen on "floating" w/o a mount...except for the OP's.
Re: Will this pass tech [Re: Mr.Yuck] #1073157
09/11/11 05:28 PM
09/11/11 05:28 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
It looks to me like it`s mounted rigid to the rear bowl w/a straight fitting........first I`ve seen but what the hell.............
Re: Will this pass tech [Re: Thumperdart] #1073158
09/11/11 08:30 PM
09/11/11 08:30 PM
ill
dennismopar73 Offline
ill
clean it up, paint those headers, hahaha lol
youre ok, good to go
Re: Will this pass tech [Re: 87MO DAK] #1073159
09/11/11 08:39 PM
09/11/11 08:39 PM
Az
Crizila Offline
Crizila  Offline
Az
This is what you need to do - but it probably will pass - but not without comment.
Fastest 300
Re: Will this pass tech [Re: Crizila] #1073160
09/11/11 08:53 PM
09/11/11 08:53 PM
Ma
Voluster Offline
Voluster  Offline
Ma
I've seen alot worse pass
Re: Will this pass tech [Re: Mr.Yuck] #1073161
09/11/11 08:56 PM
09/11/11 08:56 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Now you have... No bracket, plenty of lines to keep it in place
I would get rid of the hard fitting on the back bowl and run 2 pieces of braided.
Re: Will this pass tech [Re: 87MO DAK] #1073162
09/11/11 10:07 PM
09/11/11 10:07 PM
Lehigh Acres, Florida
rickstershemi Offline
WIX 51515R
Rickster
Re: Will this pass tech [Re: rickstershemi] #1073163
09/11/11 10:39 PM
09/11/11 10:39 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
At my dads home track they would probably still give you grief about that fuel line being in the area of the bellhousing. Happened to me at Vegas too and I ended up running the fuel line up the inner fenderwell and mounting the regulator on the inner fender. I just used a plastic cover over the line in the fenderwell as I was more worried about debris kicked up by the tire hitting the aluminum line.
Re: Will this pass tech [Re: J_BODY] #1073164
09/12/11 10:09 PM
09/12/11 10:09 PM
NY,Poughkeepsie
87MO DAK Offline OP
87MO DAK  Offline OP
NY,Poughkeepsie
I decided to make a bracket...
Thanks for the input.
Re: Will this pass tech [Re: 87MO DAK] #1073165
09/12/11 10:12 PM
09/12/11 10:12 PM
NY,Poughkeepsie
87MO DAK Offline OP
87MO DAK  Offline OP
NY,Poughkeepsie
I think I might get a straight fitting ,for the feed .
Its not permanent ,I just want to go for the local mopar
race in a couple of weeks.
Re: Will this pass tech [Re: 87MO DAK] #1073166
09/13/11 02:25 PM
09/13/11 02:25 PM
Greenville, South Carolina
BBLM23 Offline
BBLM23  Offline
I have one of those brackets that goes under the carb to hold the regulator on the side of the carb sitting in the basement. I think what you have will be fine.
Walter
1969 Dart Swinger w/ARC Pump Gas 493 B1/BS 10.18 at 130mph
Racing Pro in street trim.
1981 Aries ARC 548 B1 8.88 at 147mph (footbraking)
1996 Ram 2500 V10 16.52 at 80mph
1981 Reliant 400
Re: Will this pass tech [Re: BBLM23] #1073167
09/13/11 06:38 PM
09/13/11 06:38 PM
Abilene,Texas
ram87 Offline
ram87  Offline
Abilene,Texas
Extended a bracket under the carburetor so that the lines would not have to make sharp bends. Cheap and easy to make.
Re: Will this pass tech [Re: 87MO DAK] #1073168
09/13/11 07:18 PM
09/13/11 07:18 PM
wisconSIN
Blown61 Offline
Blown61  Offline
wisconSIN
You do know that those regs only have a .25 dia opening in them? all those big hoses aren't doing much.
