Re: Will this pass tech
[Re: HotRodDave]
#1073152
09/11/11 03:26 PM
09/11/11 03:26 PM
Posts: 115 NY,Poughkeepsie
87MO DAK
NY,Poughkeepsie
If I was a tech guy I would pass the fuel lines but not the FRAM oil filter
Its an HP1 ..Im going to change it ,but what is good? I can get a WIX cheap. Thanks
[Re: DoubleD]
#1073154
09/11/11 04:43 PM
09/11/11 04:43 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
probably will pass - but unless you like under hood fires that regulator should be firmly mounted. That's a bunch a weight hanging off an aluminum thin wall pipe - be safe and mount it right.
it will pass but dude take 10 minutes and make a bracket for it.
[Re: sam64]
#1073156
09/11/11 04:59 PM
09/11/11 04:59 PM
Mr.Yuck
Brookeville, Md
chuck nuytten carbs says regulators should not be hard mounted,of course he was telling me thats why the complete fuel system and carb that i got from him speced to my engine wouldn't work right.said vibration from being mounted won't let regulator work right.it didn't cure the problem i was having,ended up selling that carb and put mine back on.
What? Never heard of such a thing. I've never seen on "floating" w/o a mount...except for the OP's.
[Re: 87MO DAK]
#1073159
09/11/11 08:39 PM
09/11/11 08:39 PM
Posts: 7,506 Az
Crizila
Az
This is what you need to do - but it probably will pass - but not without comment.
Fastest 300
[Re: 87MO DAK]
#1073162
09/11/11 10:07 PM
09/11/11 10:07 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
WIX 51515R ![](/ubbthreads/images/graemlins/Twocents.gif)
Rickster
[Re: 87MO DAK]
#1073166
09/13/11 02:25 PM
09/13/11 02:25 PM
Posts: 2,273 Greenville, South Carolina
BBLM23
I have one of those brackets that goes under the carb to hold the regulator on the side of the carb sitting in the basement. I think what you have will be fine.
Walter 1969 Dart Swinger w/ARC Pump Gas 493 B1/BS 10.18 at 130mph Racing Pro in street trim. 1981 Aries ARC 548 B1 8.88 at 147mph (footbraking) 1996 Ram 2500 V10 16.52 at 80mph 1981 Reliant 400
[Re: 87MO DAK]
#1073168
09/13/11 07:18 PM
09/13/11 07:18 PM
Posts: 1,572 wisconSIN
Blown61
wisconSIN
I decided to make a bracket... Thanks for the input.
You do know that those regs only have a .25 dia opening in them? all those big hoses aren't doing much.
[Re: Blown61]
#1073169
09/13/11 07:40 PM
09/13/11 07:40 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Still bigger than the .110 in a holley stock needle and seat ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Mr.Yuck]
#1073171
09/13/11 08:20 PM
09/13/11 08:20 PM
Challenger 1
Cincinnati, Ohio
Then you never had a car with enough power to shake the tires.
Yes that's correct, never solid mount a regulator or any spring loaded bypasses valves. Vibration will cause them problems. Same with psi gauges. Plus like what side, thin wall aluminum fittings will crack from vibration with something hanging off of there like that. Too bad we can't see how these cars are plumbed that catch on fire because I bet the owners learned a expensive lesson.
