Powerflite Transmission to 727?? help! #1062632
08/24/11 10:59 PM
08/24/11 10:59 PM
NJ
N
Nunrunnerdart Offline OP
N
NJ
Hey guys whats up. I just purchased a 59 plymouth belvedere with a 413/ 2speed powerflite. The trans took a dump and was wondering if i could throw in a 727 behind the 413 that i have laying around. I know the drive shaft will be differnet and ill give up the pushbutton but i would much rather have the durabilty and driveability of the 727. Not sure whats behind the Bell, I am going to pull apart this week no matter what, but just wondering if anyone had any insight. Thanks!
Re: Powerflite Transmission to 727?? help! [Re: Nunrunnerdart] #1062633
08/25/11 12:00 AM
08/25/11 12:00 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Depends on the year of the 413,as long as it is 62 or newer you can use a 727,if 61 or older you will have to change the crank.Also that is a 60,not a 59.
Re: Powerflite Transmission to 727?? help! [Re: 62maxwgn] #1062634
08/25/11 09:49 AM
08/25/11 09:49 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Cheaper to find a BB iron trans and the TF buttons.The crank as said is different from a 62 up.Ive nere seen a BB with a 2 speed.All Ive seen are TFs.I beieve the 55 with the 331 had some with the 2 spd trans.Rocky
Chrysler Firepower
Re: Powerflite Transmission to 727?? help! [Re: Nunrunnerdart] #1062635
08/25/11 05:45 PM
08/25/11 05:45 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A '60 Plymouth wouldn't have come with a 413, largest was a 383 and that was always coupled to a Torqueflight not a Powerflite.
Is the distributor in the front or rear?
How many buttons on the pushbutton quadrant? Five buttons is a Torqueflight, four buttons is a Powerflite.
Re: Powerflite Transmission to 727?? help! [Re: John_Kunkel] #1062636
08/25/11 06:04 PM
08/25/11 06:04 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I believe the trans year you want will be a 62. First year for the aluminum case and last year that the buttons in your car (IF it is a Torqueflite) will work. If you do indeed have a 2 speed in it you could get a set of 3 spd buttons.
Kevin
Re: Powerflite Transmission to 727?? help! [Re: Twostick] #1062637
08/25/11 09:29 PM
08/25/11 09:29 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
62 Trans is aluminum not cast iron.The early motors had an extended crank.The convertor for early motors is completely different than a 62.The crank would still need changed.I agree thats a 60.The motor can be a 413 if it was changed.Possibly they hooked up a 2 speed button setup to a TF trans.Rocky
Chrysler Firepower
Re: Powerflite Transmission to 727?? help! [Re: Nunrunnerdart] #1062638
08/26/11 06:27 AM
08/26/11 06:27 AM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
I may be reading the post wrong, but the OP says that he is willing to give up the pushbutton. If he is willing to either change the steering column to a later model in order to fabricate shifter linkage, or use an aftermarket shifter with a 66 up torqueflite, the possibilities are endless. Of course the entire rearend would have to be changed in order to have an emergency brake setup and the driveshaft would have to be changed.
Re: Powerflite Transmission to 727?? help! [Re: rbstroker] #1062639
08/26/11 06:40 AM
08/26/11 06:40 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
First he has to find out what motor it is.Ive never seen a BB with a 2 speed trans.That and if its a early engine the crank will definetly need changed to use a late trans.Rocky
Chrysler Firepower
Re: Powerflite Transmission to 727?? help! [Re: therocks] #1062640
08/26/11 07:31 AM
08/26/11 07:31 AM
Ky.
dart67 Offline
dart67  Offline
Ky.
Is it just me......or does the jackstand set-up look like a disaster waiting to happen? Be a cold day in the deep south before I'd crawl under that.
Re: Powerflite Transmission to 727?? help! [Re: dart67] #1062641
08/26/11 11:19 AM
08/26/11 11:19 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Has nothing to do with the OP's question!
Re: Powerflite Transmission to 727?? help! [Re: 62maxwgn] #1062642
08/26/11 11:22 AM
08/26/11 11:22 AM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
the car pictured is a 60 ,,,heres my 59
Re: Powerflite Transmission to 727?? help! [Re: dynamite] #1062643
08/26/11 01:16 PM
08/26/11 01:16 PM
BTW, I had a 1959 dodge Coronet with a 326 Poly motor that came stock with a push button two speed Powerflyte
Re: Powerflite Transmission to 727?? help! [Re: Cab_Burge] #1062644
08/26/11 02:05 PM
08/26/11 02:05 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
326 is a small block.He says its a 413 with a 2 speed.Never saw one in 45 years.I had a 59 Plymouth with a poly and 2 speed trans also.Cost me 25 bucks when I bought it.Rocky
Chrysler Firepower
