440 intake holley sd vs. edelbrock rpm performer #1054104
08/16/11 04:48 PM
08/16/11 04:48 PM
st.cloud fl
d-150 Offline OP
Smarter than a 5th grader?
d-150  Offline OP
st.cloud fl
finishing 440 voodoo 04 cam 10.5 to 1 .what intake
Re: 440 intake holley sd vs. edelbrock rpm performer [Re: d-150] #1054105
08/16/11 05:07 PM
08/16/11 05:07 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Either work good!
I like the RPM performer
Re: 440 intake holley sd vs. edelbrock rpm performer [Re: d-150] #1054106
08/16/11 05:15 PM
08/16/11 05:15 PM
SD is very low profile & reportedly has good low end for a single plane & it's a spreadbore. rpm performer is very tall & reportedly good top end for a dual plane & it's a square bore. I have a SD but no actual exp w it yet
Re: 440 intake holley sd vs. edelbrock rpm performer [Re: RapidRobert] #1054107
08/16/11 05:32 PM
08/16/11 05:32 PM
Florida STAYcation
dOc ! Online penguin-006
The village idiot's idiot
dOc !  Online Penguin-006
Florida STAYcation
My vote is ferr the Berri !
Re: 440 intake holley sd vs. edelbrock rpm performer [Re: dOc !] #1054108
08/16/11 07:17 PM
08/16/11 07:17 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
I have both to try out!
From what I recall from a previous magazine article............
the Perf. RPM had more torque in the low-end as would be likely......but not much.
Re: 440 intake holley sd vs. edelbrock rpm performer [Re: Dean_Kuzluzski] #1054109
08/16/11 08:47 PM
08/16/11 08:47 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I've used both on 440's before, the same engine even. The RPM is much better but does cause clearance issues. SD isn't bad at all, but I would go w/ the RPM if possible.
I want my fair share
Re: 440 intake holley sd vs. edelbrock rpm performer [Re: SomeCarGuy] #1054110
08/16/11 08:56 PM
08/16/11 08:56 PM
Kirkland, Washington
Pacnorthcuda Offline
I too have used both on a 440. Switched other items at the same time though, went from a Holley SD to the Eddy RPM while switching the cam from a big old-school General Dynamics to a Voodoo 60303.
Therefore not a great comparison, but I certainly like the Eddy and have no reason to believe the SD is superior in any way.
I do believe they are pretty darn similiar in performance.
Re: 440 intake holley sd vs. edelbrock rpm performer [Re: Pacnorthcuda] #1054111
08/20/11 12:14 AM
08/20/11 12:14 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
... went from a Holley SD to the Eddy RPM while switching the cam from a big old-school General Dynamics to a Voodoo 60303.
General Dynamics is a Defense Contractor. Unless you had a cam for a tank or submarine in you engine, You had either a General Kinetics or Cam Dynamics cam.
Re: 440 intake holley sd vs. edelbrock rpm performer [Re: GomangoCuda] #1054112
08/20/11 02:33 AM
08/20/11 02:33 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I had the SD on my old mild 440 that was in my 63 and I really liked it. It actually had very good low end for the combo. Best of 11.49 with a best 60 of 1.57. It was a 906 headed 440 with the MP .557 cam and a 850 DP. Ron
Re: 440 intake holley sd vs. edelbrock rpm performer [Re: GomangoCuda] #1054113
08/21/11 01:28 AM
08/21/11 01:28 AM
Rome, GA
GTXX Offline
GTXX  Offline
Rome, GA
