Re: 440 intake holley sd vs. edelbrock rpm performer
[Re: d-150]
#1054106
08/16/11 05:15 PM
08/16/11 05:15 PM
RapidRobert
SD is very low profile & reportedly has good low end for a single plane & it's a spreadbore. rpm performer is very tall & reportedly good top end for a dual plane & it's a square bore. I have a SD but no actual exp w it yet
[Re: dOc !]
#1054108
08/16/11 07:17 PM
08/16/11 07:17 PM
Posts: 8,943 Holly/MI
Dean_Kuzluzski
Holly/MI
I have both to try out! ![](/ubbthreads/images/graemlins/biggrin.gif) From what I recall from a previous magazine article............ the Perf. RPM had more torque in the low-end as would be likely......but not much.
[Re: Dean_Kuzluzski]
#1054109
08/16/11 08:47 PM
08/16/11 08:47 PM
Posts: 10,232 Someplace you aren't
SomeCarGuy
I've used both on 440's before, the same engine even. The RPM is much better but does cause clearance issues. SD isn't bad at all, but I would go w/ the RPM if possible.
I want my fair share
[Re: Pacnorthcuda]
#1054111
08/20/11 12:14 AM
08/20/11 12:14 AM
Posts: 4,758 Moved to N.E. Tennessee
GomangoCuda
... went from a Holley SD to the Eddy RPM while switching the cam from a big old-school General Dynamics to a Voodoo 60303.
General Dynamics is a Defense Contractor. Unless you had a cam for a tank or submarine in you engine, You had either a General Kinetics or Cam Dynamics cam.
[Re: GomangoCuda]
#1054113
08/21/11 01:28 AM
08/21/11 01:28 AM
Posts: 176 Rome, GA
GTXX
Rome, GA
![](/ubbthreads/images/graemlins/haha.gif)
