Re: Clutch ???? for a 440+6 in a 70 b-body [Re: ramcuda] #1048988
08/10/11 04:58 AM
08/10/11 04:58 AM
VA.
mosweethemi Offline
mosweethemi  Offline
VA.
Hello I have a 1970 Road Runner six pack car and a 1968 Hemi car, Both are four speed car. The Clutchs both came from Wayne Brewer! The one in the Hemi car has been in it for 12 years 354 rear and the six pack for around two years 410 rear.I have bad legs!also and they or not that bad at stop lights with the clutch push in!! Call Wayne!!
Re: Clutch ???? for a 440+6 in a 70 b-body [Re: mosweethemi] #1048989
08/10/11 12:12 PM
08/10/11 12:12 PM
warfordsburg, PA
dirt Offline
dirt  Offline
warfordsburg, PA
i just got the clutch for a 440- 6 cuda and i ordered a 10.95" kit from ram. you can use the 10.95 clutch with the 130 tooth flywheel and bellhousing. if you go to 11" you need the 143 tooth flywheel and different bellhousing, i know that from my last experience trying to fit a 11
' clutch in a 10.5" bell.
anyway the 10.95 disc from ram still was only 10 7/16 , i'm trying to figure out if they screwed up or its supposed to be that way
hope it helps a little
Re: Clutch ???? for a 440+6 in a 70 b-body [Re: dirt] #1048990
08/10/11 01:41 PM
08/10/11 01:41 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
You will like that clutch setup.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Clutch ???? for a 440+6 in a 70 b-body [Re: ramcuda] #1048991
08/10/11 03:52 PM
08/10/11 03:52 PM
dogdays Offline
dogdays  Offline
Not if you want to decrease pedal effort. What you have listed is the Borg and Beck style. The diaphragm style will have a much lighter clutch for the same clamping force.
R.
Re: Clutch ???? for a 440+6 in a 70 b-body [Re: dogdays] #1048992
08/10/11 06:06 PM
08/10/11 06:06 PM
Santa Clara , ca
ramcuda Offline OP
ramcuda  Offline OP
Santa Clara , ca
Wayne !!!!!
PM FOR YOU ....
1965 Ply "RAMCUDA" got to see it!!!<--- Should sell it/
1970 Superbird <------ Just one big argument/
1980 Jeep CJ5 <--- Just wheel it/
2000 Dakota R/T <--- Should Drive it more/
2001 Dodge Caravan <----- Cant kill it/
2004 Dodge 2500 4dr DIZLE 4x4 <---- LOVE IT !!!
www.moparalley.org
Re: Clutch ???? for a 440+6 in a 70 b-body [Re: 70sixpkrt] #1048993
08/10/11 06:33 PM
08/10/11 06:33 PM
Birmingham, England
Mick70RR Offline
Mick70RR  Offline
Birmingham, England
Mick70RR the clutch your using is for a 143 tooth flywheel. His is probably a stock 130 tooth.
You want this http://www.brewersperformance.com/proddetail.asp?prod=MC1018
or
http://www.brewersperformance.com/proddetail.asp?prod=MCP1018
Yes that's right, I have a 143 tooth flywheel and guessed the OP did too. This clutch I'm using ( in the link I posted ) is big, I think when I measured the clutch plate it was just under 12 inches diameter.
1970 Road Runner 505 cid MCH CNC ported Stealth heads MP 528 camshaft 4 speed GV overdrive 11.98 @ 117 on street treads
