Clutch ???? for a 440+6 in a 70 b-body #1048968
08/08/11 01:57 AM
08/08/11 01:57 AM
Santa Clara , ca
ramcuda Offline OP
ramcuda  Offline OP
Santa Clara , ca
Ok
Asked one time to many im sure....
Ok she has driven the clutch out of the car ..
We have a stock or a OE Borg in there and is out ...
Center force is not making the DF for a 18splin any more ...
So what is every one running now ????
Mind you it a 70 440+6 car so I'm looking for better than stock but I not looking for a race race set up and something that not going to bust my knee as it get driven alot
David
1965 Ply "RAMCUDA" got to see it!!!<--- Should sell it/
1970 Superbird <------ Just one big argument/
1980 Jeep CJ5 <--- Just wheel it/
2000 Dakota R/T <--- Should Drive it more/
2001 Dodge Caravan <----- Cant kill it/
2004 Dodge 2500 4dr DIZLE 4x4 <---- LOVE IT !!!
www.moparalley.org
Re: Clutch ???? for a 440+6 in a 70 b-body [Re: ramcuda] #1048969
08/08/11 02:01 AM
08/08/11 02:01 AM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
Here is a McLeod package that is very similar to the Centerforce dual friction package:
http://www.brewersperformance.com/proddetail.asp?prod=MCDP1018
Wayne
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
Re: Clutch ???? for a 440+6 in a 70 b-body [Re: ramcuda] #1048970
08/08/11 07:33 AM
08/08/11 07:33 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
11" Sachs 3 finger BB style pressure plate with a Sachs Kelvar disc,...best street/strip set-up IMO, it's what I have behind my 440/6..2800 lbs up to 3400 lbs avaliable ratings
Re: Clutch ???? for a 440+6 in a 70 b-body [Re: DAYCLONA] #1048971
08/08/11 02:31 PM
08/08/11 02:31 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
Mcleod street/strip setup. Disc 260151, pp 360153, to bearing 16061.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Clutch ???? for a 440+6 in a 70 b-body [Re: ramcuda] #1048972
08/08/11 02:39 PM
08/08/11 02:39 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
Just installed a centerforce dual friction clutch in My 69 Bee...440(30 over) 6 pack...Completely satisfied..also installed the same setup in a 498 stroker and it was excellent. I'm sure there are others out there but just passing along My experience. They claim this clutch was good for up to 600 hp. Pedal pressure is mild.
Re: Clutch ???? for a 440+6 in a 70 b-body [Re: terzmo] #1048973
08/08/11 05:14 PM
08/08/11 05:14 PM
dogdays Offline
dogdays  Offline
He said the CF is discontinued in his spline count.
R.
Re: Clutch ???? for a 440+6 in a 70 b-body [Re: dogdays] #1048974
08/08/11 09:47 PM
08/08/11 09:47 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
EXCUSE Me !!!
Re: Clutch ???? for a 440+6 in a 70 b-body [Re: terzmo] #1048975
08/09/11 12:34 AM
08/09/11 12:34 AM
Wendy, I'm home.
dstryr Offline
dstryr  Offline
Wendy, I'm home.
I've had a 12" McLeod setup in my 6bbl Road Runner for 8 years and am happy with it
360250 12" pressure plate street p/p
260653 12" disc, 18spline 600 series disc
16061 TO bearing
dstryr, since 1986.
Re: Clutch ???? for a 440+6 in a 70 b-body [Re: dstryr] #1048976
08/09/11 06:20 AM
08/09/11 06:20 AM
Santa Clara , ca
ramcuda Offline OP
ramcuda  Offline OP
Santa Clara , ca
Sorry forgot to say it a 10 1/2 in,,
I was looking at the Mcleod stuff and what you guys think about this ?
Plate PN# plate 260150 spec
Cover PN# cover 360153 spec
www.moparalley.org
Re: Clutch ???? for a 440+6 in a 70 b-body [Re: ramcuda] #1048977
08/09/11 10:39 AM
08/09/11 10:39 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Sachs offers a 10 1/2" set up as well, are you sure it's not a "scallop" set-up 10.750 IIRC....
Re: Clutch ???? for a 440+6 in a 70 b-body [Re: ramcuda] #1048978
08/09/11 11:21 AM
08/09/11 11:21 AM
Moved to N.E. Tennessee
GomangoCuda Online work
GomangoCuda  Online Work
The one recommended by Brewer would be a lot more similar to a Centerforce dual friction if that was what you were wanting. The diaphram PP is a lot easier on the leg than a B&B style and the 500 series disc is similar to centerforces DF.
I use the 500 series disc that has organic on one side and ceramic on the other side and a 360951 Borg&beck/Long pressure plate. This is a 10.95 Unit that will fit on your 10.5 flywheel and accept the 11" disc. For your 18 spline trany you would need a 260551 disc. This setup has been my favorite for many years. I think it is a nice compromise. It requires less leg effort than a B&B and shifts better at high rpm. The fingers are counterweighted to add pressure due to centrifugal force and weight can be added to them if needed. It is however somewhat pricier than the diaphram kit that Brewer is selling and I am sure either one would work fine for you.
http://www.mcleodracing.com/products/500+Series+Disc.mcl
http://www.mcleodracing.com/products/Borg+%26+Beck+Long+Pressure+Plates.mcl
By the way the 360153 pressure plate you mentioned is also a 10.95 that fits on a 10.5 flywheel and you can use a 260151 11" organic/organic disc or a 260551 11" organic/ceramic disc with it. Mcleods 11" discs are slightly undersized so that they work with both 10.95 and 11" pressure plates.
Re: Clutch ???? for a 440+6 in a 70 b-body [Re: DAYCLONA] #1048979
08/09/11 11:29 AM
08/09/11 11:29 AM
It should be a scalloped 10.95" unit on a 130 tooth flywheel.
Re: Clutch ???? for a 440+6 in a 70 b-body [Re: GomangoCuda] #1048980
08/09/11 05:44 PM
08/09/11 05:44 PM
Santa Clara , ca
ramcuda Offline OP
ramcuda  Offline OP
Santa Clara , ca
ok i think its scalloped ...
MIND YOU ALL I HAVEN'T A CLUE ABOUT CLUTCH STUFF ....
here is a pic of the cover ..
and the peddle is ok just dont want it heaver .. Debi broke her foot and the bones in the top of her foot get sore after a while
www.moparalley.org
Re: Clutch ???? for a 440+6 in a 70 b-body [Re: ramcuda] #1048981
08/09/11 06:16 PM
08/09/11 06:16 PM
70sixpkrt Offline
70sixpkrt  Offline
That looks like a Borg and Beck type clutch to me. I would call Bob Mazzolini Racing and ask him about clutches. I got mine from him.
4-speed
3:54 Dana
Re: Clutch ???? for a 440+6 in a 70 b-body [Re: ramcuda] #1048982
08/09/11 06:21 PM
08/09/11 06:21 PM
Birmingham, England
Mick70RR Offline
Mick70RR  Offline
Birmingham, England
This is the clutch I fitted about two years ago. Car is driven daily and I have at least 100 launches on it at the local drag strip. I only adjusted it once, a few hundred miles after it was fitted.
http://www.brewersperformance.com/proddetail.asp?prod=MCP1118
1970 Road Runner 505 cid MCH CNC ported Stealth heads MP 528 camshaft 4 speed GV overdrive 11.98 @ 117 on street treads
Re: Clutch ???? for a 440+6 in a 70 b-body [Re: Mick70RR] #1048983
08/09/11 06:34 PM
08/09/11 06:34 PM
70sixpkrt Offline
70sixpkrt  Offline
Mick70RR the clutch your using is for a 143 tooth flywheel. His is probably a stock 130 tooth.
You want this http://www.brewersperformance.com/proddetail.asp?prod=MC1018
or
http://www.brewersperformance.com/proddetail.asp?prod=MCP1018
4-speed
3:54 Dana
Re: Clutch ???? for a 440+6 in a 70 b-body [Re: 70sixpkrt] #1048984
08/09/11 06:36 PM
08/09/11 06:36 PM
Birmingham, England
Mick70RR Offline
Mick70RR  Offline
Birmingham, England
From the first post I assumed it was an 18 spline.
Re: Clutch ???? for a 440+6 in a 70 b-body [Re: Mick70RR] #1048985
08/09/11 06:40 PM
08/09/11 06:40 PM
70sixpkrt Offline
70sixpkrt  Offline
It is an 18 spline.
4-speed
3:54 Dana
Re: Clutch ???? for a 440+6 in a 70 b-body [Re: ramcuda] #1048986
08/09/11 06:42 PM
08/09/11 06:42 PM
dogdays Offline
dogdays  Offline
There's a lot of good info posted here.
First of all you have a big motor and need all the clutch you can get so use the 10.95" setup that bolts onto your 10.5" flywheel. Dollars to doughnuts that's what you have now.
Second if you want to minimize your pedal pressure the diaphragm clutch is the way to go. It'll cut your pedal pressure way down for the same clamping force. Your Centerforce idea was on the money, and you should be able to get a CF pressure plate because it has many applications.
Just buy the set in this link which I copied from up the thread:
http://www.brewersperformance.com/proddetail.asp?prod=MCDP1018 Be sure to get the throwout bearing to go with it and to pack the TO bearing with grease unless it is "lifetime lubed".
Back in the day my brother and I put a 3500# clutch in his 67 GTO and we were so green we put the throwout bearing in dry. The clutch was a bear to disengage, but no worries because in about 300 miles the throwout bearing had worn the clutch fingers about off. So he kept the disk and went with a lighter plate and that time we greased the bearing and it lived. Maybe all throwout bearings are sealed now, but we had to learn the hard way.
Good luck and ask questions if you don't know the answer.
R.
Re: Clutch ???? for a 440+6 in a 70 b-body [Re: dogdays] #1048987
08/10/11 04:40 AM
08/10/11 04:40 AM
Santa Clara , ca
ramcuda Offline OP
ramcuda  Offline OP
Santa Clara , ca
I called mcleod today and after chating with there Tech guy
We came up with this combo
Cover 360156
Plate 260551
Witch look to be about the same as the
MCP1018 McLEOD 10.95" 18 SPLINE PERFORMANCE CLUTCH PKG
Is there a Moparts Discount threw Brewer's ???
Am I on the right track now ????
www.moparalley.org
