Clutch ???? for a 440+6 in a 70 b-body
#1048968
08/08/11 01:57 AM
08/08/11 01:57 AM
Posts: 267 Santa Clara , ca
ramcuda
Santa Clara , ca
Ok
Asked one time to many im sure....
Ok she has driven the clutch out of the car ..
We have a stock or a OE Borg in there and is out ...
Center force is not making the DF for a 18splin any more ...
So what is every one running now ????
Mind you it a 70 440+6 car so I'm looking for better than stock but I not looking for a race race set up and something that not going to bust my knee as it get driven alot
Thanks David
1965 Ply "RAMCUDA" got to see it!!!<--- Should sell it/ 1970 Superbird <------ Just one big argument/ 1980 Jeep CJ5 <--- Just wheel it/ 2000 Dakota R/T <--- Should Drive it more/ 2001 Dodge Caravan <----- Cant kill it/ 2004 Dodge 2500 4dr DIZLE 4x4 <---- LOVE IT !!! www.moparalley.org
Re: Clutch ???? for a 440+6 in a 70 b-body
[Re: terzmo]
#1048975
08/09/11 12:34 AM
08/09/11 12:34 AM
Posts: 2,966 Wendy, I'm home.
dstryr
Wendy, I'm home.
I've had a 12" McLeod setup in my 6bbl Road Runner for 8 years and am happy with it
360250 12" pressure plate street p/p 260653 12" disc, 18spline 600 series disc 16061 TO bearing
dstryr, since 1986.
[Re: dstryr]
#1048976
08/09/11 06:20 AM
08/09/11 06:20 AM
ramcuda
Santa Clara , ca
Sorry forgot to say it a 10 1/2 in,, I was looking at the Mcleod stuff and what you guys think about this ? Plate PN# plate 260150 spec Cover PN# cover 360153 spec
[Re: GomangoCuda]
#1048980
08/09/11 05:44 PM
08/09/11 05:44 PM
ramcuda
Santa Clara , ca
ok i think its scalloped ... MIND YOU ALL I HAVEN'T A CLUE ABOUT CLUTCH STUFF .... here is a pic of the cover .. and the peddle is ok just dont want it heaver .. Debi broke her foot and the bones in the top of her foot get sore after a while
[Re: ramcuda]
#1048982
08/09/11 06:21 PM
08/09/11 06:21 PM
Posts: 288 Birmingham, England
Mick70RR
Birmingham, England
This is the clutch I fitted about two years ago. Car is driven daily and I have at least 100 launches on it at the local drag strip. I only adjusted it once, a few hundred miles after it was fitted. http://www.brewersperformance.com/proddetail.asp?prod=MCP1118
1970 Road Runner
505 cid
MCH CNC ported Stealth heads
MP 528 camshaft
4 speed
GV overdrive
11.98 @ 117 on street treads
[Re: 70sixpkrt]
#1048984
08/09/11 06:36 PM
08/09/11 06:36 PM
Mick70RR
Birmingham, England
From the first post I assumed it was an 18 spline.
1970 Road Runner
505 cid
MP 528 camshaft
4 speed
GV overdrive
[Re: ramcuda]
#1048986
08/09/11 06:42 PM
08/09/11 06:42 PM
dogdays
There's a lot of good info posted here. First of all you have a big motor and need all the clutch you can get so use the 10.95" setup that bolts onto your 10.5" flywheel. Dollars to doughnuts that's what you have now. Second if you want to minimize your pedal pressure the diaphragm clutch is the way to go. It'll cut your pedal pressure way down for the same clamping force. Your Centerforce idea was on the money, and you should be able to get a CF pressure plate because it has many applications. Just buy the set in this link which I copied from up the thread: http://www.brewersperformance.com/proddetail.asp?prod=MCDP1018 Be sure to get the throwout bearing to go with it and to pack the TO bearing with grease unless it is "lifetime lubed". Back in the day my brother and I put a 3500# clutch in his 67 GTO and we were so green we put the throwout bearing in dry. The clutch was a bear to disengage, but no worries because in about 300 miles the throwout bearing had worn the clutch fingers about off. So he kept the disk and went with a lighter plate and that time we greased the bearing and it lived. Maybe all throwout bearings are sealed now, but we had to learn the hard way. Good luck and ask questions if you don't know the answer. R.
[Re: dogdays]
#1048987
08/10/11 04:40 AM
08/10/11 04:40 AM
ramcuda
Santa Clara , ca
I called mcleod today and after chating with there Tech guy We came up with this combo Cover 360156 Plate 260551 Witch look to be about the same as the MCP1018 McLEOD 10.95" 18 SPLINE PERFORMANCE CLUTCH PKG Is there a Moparts Discount threw Brewer's ??? Am I on the right track now ????
