Re: How do YOU slow down YOUR car for index racing?
[Re: ProSport]
#1045083
08/02/11 06:48 PM
08/02/11 06:48 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Mike do you have a pic of that mounted on the carb?(Pbody)
Bob... no I dont... I made it to fit my 1050 dom... the pin fits into a hole in the base and then the other end goes over the mounting stud... here is a pic of the hole
[Re: Jeepmon]
#1045085
08/02/11 09:27 PM
08/02/11 09:27 PM
MR_P_BODY
Mike.. where did you get the bracket? and did it already have a hole for the threaded rod, or did you have to modify it?
I made the whole thing... a piece of flat stock that I bent 90*, contoured it, welded a 1/4x20 nut to it at the angle I needed and a piece of 1/4x20 threaded rod... and a piece of round stock I had that fit the hole that I welded on so its nice and stable took all of about 1 1/2 hours from design to done and working
[Re: nss guy]
#1045088
08/02/11 09:52 PM
08/02/11 09:52 PM
Posts: 8,094 Sunnyvale, CA
Jeepmon
Sunnyvale, CA
For me when indexing racing I just run to a predetermine spot and lift...
Thats what I'll do... Thanks for reminding me of this..
[Re: Jeepmon]
#1045092
08/03/11 11:39 AM
08/03/11 11:39 AM
Posts: 4,219 New York
polyspheric
New York
Blocking the secondaries will work (duh!), but its' a bit dangerous. If the engine is big enough, the high vacuum in the primaries will shut the power valve.
Boffin Emeritus
[Re: polyspheric]
#1045093
08/03/11 09:55 PM
08/03/11 09:55 PM
Posts: 2,316 NE Ohio
DoubleD
NE Ohio
Might - but "Dangerous" - I doubt - you been hanging around too many attorneys!!!
The engine may lean down some - my experience doing this is you normally have to take the jets up by two and bring the timing back a little and watch your plugs. The advantage to taking out the secondaries is you get the full pump shot at launch versus running partial throttle against a stop
[Re: DoubleD]
#1045094
08/03/11 10:18 PM
08/03/11 10:18 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
The 2010 track champion at acto,cecil,and I think raceway park in 10.0 index runs with his secondarys disconnected. He takes off a half second by doing this and pulling timing.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: DoubleD]
#1045095
08/03/11 10:18 PM
08/03/11 10:18 PM
MR_P_BODY
I never had any issue on the pump shot... its getting 2... 1/2 volume shots but takes in alot less air so to me that was a wash
[Re: Al_Alguire]
#1045097
08/04/11 02:02 AM
08/04/11 02:02 AM
Jeepmon
Sunnyvale, CA
I still say throw Jon in the trunk, maybe Wiley too. Then whomp away
Wiley stopped coming out to the track with us...
