Page 2 of 3 1 2 3
Re: How do YOU slow down YOUR car for index racing? [Re: ProSport] #1045083
08/02/11 06:48 PM
08/02/11 06:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Mike do you have a pic of that mounted on the carb?(Pbody)
Bob... no I dont... I made it to fit my 1050 dom...
the pin fits into a hole in the base and then the other
end goes over the mounting stud... here is a pic of
the hole
Re: How do YOU slow down YOUR car for index racing? [Re: MR_P_BODY] #1045084
08/02/11 09:17 PM
08/02/11 09:17 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Mike.. where did you get the bracket? and did it already have a hole for the threaded rod, or did you have to modify it?
Re: How do YOU slow down YOUR car for index racing? [Re: Jeepmon] #1045085
08/02/11 09:27 PM
08/02/11 09:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I made the whole thing... a piece of flat stock that
I bent 90*, contoured it, welded a 1/4x20 nut to it at
the angle I needed and a piece of 1/4x20 threaded rod...
and a piece of round stock I had that fit the hole
that I welded on so its nice and stable
took all of about 1 1/2 hours from design to done
and working
Re: How do YOU slow down YOUR car for index racing? [Re: MR_P_BODY] #1045086
08/02/11 09:42 PM
08/02/11 09:42 PM
Freeport, Pa
W
whiskeyrunner Offline
W
Freeport, Pa
10.80s all out...11.60s with the secondaries disconnected and 300 lbs in the car. car varied about 4 hun on saturday
Re: How do YOU slow down YOUR car for index racing? [Re: whiskeyrunner] #1045087
08/02/11 09:45 PM
08/02/11 09:45 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
I think someone makes the same type bracket for stopping overcentering the butterflyshttp://store.jetracinginc.com/pr910-11550.html
For me when indexing racing I just run to a predetermine spot and lift...
Re: How do YOU slow down YOUR car for index racing? [Re: nss guy] #1045088
08/02/11 09:52 PM
08/02/11 09:52 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Thats what I'll do... Thanks for reminding me of this..
Re: How do YOU slow down YOUR car for index racing? [Re: Jeepmon] #1045089
08/02/11 09:57 PM
08/02/11 09:57 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
Re: How do YOU slow down YOUR car for index racing? [Re: nss guy] #1045090
08/03/11 12:33 AM
08/03/11 12:33 AM
Las Vegas
Al_Alguire Online laugh2
Las Vegas
Spot drop....Someone is giving away secrets
Re: How do YOU slow down YOUR car for index racing? [Re: Al_Alguire] #1045091
08/03/11 09:51 AM
08/03/11 09:51 AM
Newark,Ohio
kissmyaspen Offline
kissmyaspen  Offline
Newark,Ohio
79 Dodge Aspen
12.265 at 109.75 MPH
67 Satellite NSS/E
11.83 @ 110
1968 Plymouth Road Runner 472 Hemi
3 time MOPAR NATIONALS CHAMP '03 FWD and '06 & '09 Street.
'07, '10, '12 Mopar Nats runner-up Street.
Re: How do YOU slow down YOUR car for index racing? [Re: Jeepmon] #1045092
08/03/11 11:39 AM
08/03/11 11:39 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Blocking the secondaries will work (duh!), but its' a bit dangerous.
If the engine is big enough, the high vacuum in the primaries will shut the power valve.
Boffin Emeritus
Re: How do YOU slow down YOUR car for index racing? [Re: polyspheric] #1045093
08/03/11 09:55 PM
08/03/11 09:55 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Might - but "Dangerous" - I doubt - you been hanging around too many attorneys!!!
The engine may lean down some - my experience doing this is you normally have to take the jets up by two and bring the timing back a little and watch your plugs. The advantage to taking out the secondaries is you get the full pump shot at launch versus running partial throttle against a stop
Re: How do YOU slow down YOUR car for index racing? [Re: DoubleD] #1045094
08/03/11 10:18 PM
08/03/11 10:18 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
The 2010 track champion at acto,cecil,and I think raceway park in 10.0 index runs with his secondarys disconnected. He takes off a half second by doing this and pulling timing.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: How do YOU slow down YOUR car for index racing? [Re: DoubleD] #1045095
08/03/11 10:18 PM
08/03/11 10:18 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I never had any issue on the pump shot... its getting
2... 1/2 volume shots but takes in alot less air so
to me that was a wash
Re: How do YOU slow down YOUR car for index racing? [Re: MR_P_BODY] #1045096
08/04/11 01:27 AM
08/04/11 01:27 AM
Las Vegas
Las Vegas
I still say throw Jon in the trunk, maybe Wiley too. Then whomp away
Re: How do YOU slow down YOUR car for index racing? [Re: Al_Alguire] #1045097
08/04/11 02:02 AM
08/04/11 02:02 AM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Wiley stopped coming out to the track with us...
Re: How do YOU slow down YOUR car for index racing? [Re: Jeepmon] #1045098
08/04/11 02:03 AM
08/04/11 02:03 AM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Since we're on the subject.. how much timing can you pull out of the motor and still be safe?
Re: How do YOU slow down YOUR car for index racing? [Re: Jeepmon] #1045099
08/04/11 02:06 AM
08/04/11 02:06 AM
Las Vegas
Las Vegas
We had the old Demon down to 20 degrees(from 36) trying to get it to run 9.90. Only issues I have ever had with getting to low is excessive heat, both water temp and from the pipes. Timing is one easy way to kill some ET. I still say whomp away.
Seriously you have weight for the car and a nice system to ad more. I think between adding some more weight and timing you can get close enough to race. Spot dropping is actually a VERY good idea IMO. Provided you have the time to test and find the right spot.
Re: How do YOU slow down YOUR car for index racing? [Re: Al_Alguire] #1045100
08/04/11 04:10 AM
08/04/11 04:10 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Put a bum convertor in it.
Hp is king.
Re: How do YOU slow down YOUR car for index racing? [Re: RemCharger] #1045101
08/04/11 08:50 AM
08/04/11 08:50 AM
Swamps of South Jersey.
W
wildcargo Offline
wildcargo  Offline
W
Bud www.wildcar-go.itgo.com
64 DODGE
60' 1.433,
1/8 6.38 at 107.4,
1/4 10.08 at 132.02
foot brake, leaf springs
Re: How do YOU slow down YOUR car for index racing? [Re: wildcargo] #1045102
08/04/11 09:03 AM
08/04/11 09:03 AM
Arizona
Chris'sBarracuda Offline
Arizona
Ummmmm.... Not even legal..
Chris..
Page 2 of 3 1 2 3
