Flywheel Question
#1044493
08/01/11 11:08 AM
08/01/11 11:08 AM
Posts: 3,288 Stroudsburg, PA
Erik
Stroudsburg, PA
I have the stock flywheel that was in my cuda when it was a 273. I have built a 416 stroker for it and dumped the 273. Can I use the stock flywheel with the 416 or should I get a new one?
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
Re: Flywheel Question
[Re: Erik]
#1044494
08/01/11 11:54 AM
08/01/11 11:54 AM
Posts: 4,737 Moved to N.E. Tennessee
GomangoCuda
Doesn't a 273 use a small clutch? Like 9 or 10 inches. If so then it won't like your stroker very much.
[Re: GomangoCuda]
#1044495
08/01/11 12:26 PM
08/01/11 12:26 PM
Erik
Stroudsburg, PA
The flywheel I have is 10.5" clutch - I measured it yesterday.
The 273 4-spd combo was not original to the car.
[Re: JohnRR]
#1044497
08/01/11 01:13 PM
08/01/11 01:13 PM
Erik
Stroudsburg, PA
Yes, it is a stock cast unit. Thanks, John!
[Re: dogdays]
#1044499
08/01/11 04:49 PM
08/01/11 04:49 PM
Erik
Stroudsburg, PA
Thanks. The car will mainly be street driven, so I don't see it pulling too many high rpms on a regular basis.
[Re: Erik]
#1044500
08/01/11 05:47 PM
08/01/11 05:47 PM
Posts: 75,072 U.S.S.A.
JohnRR
U.S.S.A.
famous last words with a 4 speed ...
[Re: dogdays]
#1044504
08/02/11 10:35 PM
08/02/11 10:35 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
damn $99?! someone needs to make me one of these but with the 5.9L magnum balance to them!
$150 for a stock magnum cast flywheel. $300-350 for a billet 5.9L flywheel.
edit: in a 143 tooth wheel....I saw the 440 source wheels, and they're 130 toothers.
**Photobucket sucks**
[Re: Erik]
#1044505
08/03/11 12:15 AM
08/03/11 12:15 AM
Posts: 587 IL . usa
cjs69mope
IL . usa
Be Careful with cheep China junk flywheels i think that with flywheels you get what you pay for ! someone had some issues with the source fly wheels on here a while back maybe due a search . i had a bad experiance with source water pump and learned the hard way .
1969 Dodge Charger
1969 Dodge Superbee
