Flywheel Question #1044493
08/01/11 11:08 AM
08/01/11 11:08 AM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
I have the stock flywheel that was in my cuda when it was a 273. I have built a 416 stroker for it and dumped the 273. Can I use the stock flywheel with the 416 or should I get a new one?
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
Re: Flywheel Question [Re: Erik] #1044494
08/01/11 11:54 AM
08/01/11 11:54 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Doesn't a 273 use a small clutch? Like 9 or 10 inches. If so then it won't like your stroker very much.
Re: Flywheel Question [Re: GomangoCuda] #1044495
08/01/11 12:26 PM
08/01/11 12:26 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
The flywheel I have is 10.5" clutch - I measured it yesterday.
The 273 4-spd combo was not original to the car.
Re: Flywheel Question [Re: Erik] #1044496
08/01/11 12:32 PM
08/01/11 12:32 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
As long as both are neutral balance yes you can use it BUT is the flywheel a stock cast unit ? If so I'd replace it with a new billet wheel for safety sake.
Re: Flywheel Question [Re: JohnRR] #1044497
08/01/11 01:13 PM
08/01/11 01:13 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
Yes, it is a stock cast unit. Thanks, John!
Re: Flywheel Question [Re: Erik] #1044498
08/01/11 04:08 PM
08/01/11 04:08 PM
dogdays Offline
dogdays  Offline
To go absolutely the cheapest you could use a 10.95" pressure plate and disk with that wheel. It's a stroker, no need to rev it to the trees. But if you think you will, buy a SEMA spec wheel and be safe. And if you do don't go heavier than stock, your big engine doesn't need it.
R.
Re: Flywheel Question [Re: dogdays] #1044499
08/01/11 04:49 PM
08/01/11 04:49 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
Thanks. The car will mainly be street driven, so I don't see it pulling too many high rpms on a regular basis.
Re: Flywheel Question [Re: Erik] #1044500
08/01/11 05:47 PM
08/01/11 05:47 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
famous last words with a 4 speed ...
Re: Flywheel Question [Re: JohnRR] #1044501
08/01/11 07:26 PM
08/01/11 07:26 PM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
invest in a billet wheel.
street has nothing to do with rpm.
Re: Flywheel Question [Re: Erik] #1044502
08/01/11 09:42 PM
08/01/11 09:42 PM
AndyF Online content
AndyF  Online Content
Billet flywheels are cheap these days. PRW has some really nice Mopar flywheels and they are not very expensive. I have both a 6 bolt and a 8 bolt version.
Re: Flywheel Question [Re: AndyF] #1044503
08/02/11 08:07 PM
08/02/11 08:07 PM
dogdays Offline
dogdays  Offline
I just spent 5 minutes looking at the PRW website and couldn't find a Mopar billet wheel.
However, 440Source has'em for $99.00. At that price don't mess around with a 40-year-old cast wheel. No matter what.
R.
PS: Thanks, Andy, I was stuck in the $400+ flywheel time warp.
Re: Flywheel Question [Re: dogdays] #1044504
08/02/11 10:35 PM
08/02/11 10:35 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
damn $99?! someone needs to make me one of these but with the 5.9L magnum balance to them!
$150 for a stock magnum cast flywheel. $300-350 for a billet 5.9L flywheel.
edit: in a 143 tooth wheel....I saw the 440 source wheels, and they're 130 toothers.
**Photobucket sucks**
Re: Flywheel Question [Re: Erik] #1044505
08/03/11 12:15 AM
08/03/11 12:15 AM
IL . usa
cjs69mope Offline
cjs69mope  Offline
IL . usa
Be Careful with cheep China junk flywheels i think that with flywheels you get what you pay for !
someone had some issues with the source fly wheels on here a while back maybe due a search .
i had a bad experiance with source water pump and learned the hard way .
1969 Dodge Charger 1969 Dodge Superbee
Re: Flywheel Question [Re: cjs69mope] #1044506
08/03/11 11:01 AM
08/03/11 11:01 AM
GomangoCuda Offline
GomangoCuda  Offline
Occasionally Mcleod sells overstock flywheels for a good price. They list them on their forum and on Ebay http://stores.ebay.com/McLeod-Racing-Clutches?_trksid=p4340.l2563 and Racing Junk http://www.racingjunk.com/dealers/McLeod_Racing?page=1. I paid $200 for a 130 tooth aluminum wheel. The steel ones were $120. When I bought mine they had a good assortment of Mopar flywheels for sale cheap. Actually I called to ask a question about them and bought it direct from the tech dept. They are not showing any Mopar wheels right now but I would call the tech line and ask if they have any they want to clear out. Do not call the sales line. They will tell you to buy it from Summit for almost three times the money.
