96 Dodge Ram Won't Start #1017443
06/20/11 10:23 PM
06/20/11 10:23 PM
Powell, Ohio ( Originally Pitt...
1970Dart3406 Offline OP
THis is a question froma friend of mine......
1996 Dodge Ram, 360 4x4, he was driving down the driveway, was running rough. Decided to blip the throttle to clear it out, truck died. Wouldn't restart. It cranks with good spark, will start to fire on ether. I think fuel pump, but he replaced it 2 years ago.
Any ideas?
Re: 96 Dodge Ram Won't Start [Re: 1970Dart3406] #1017444
06/20/11 10:26 PM
06/20/11 10:26 PM
Alexandria,La.
BigTerry Offline
BigTerry  Offline
Alexandria,La.
maybe try to see how much fuel pressure it got....
Re: 96 Dodge Ram Won't Start [Re: 1970Dart3406] #1017445
06/20/11 11:37 PM
06/20/11 11:37 PM
Great Lakes Region
abodiesonly1 Offline
Great Lakes Region
Check fuel pressure and injector pulse.
Re: 96 Dodge Ram Won't Start [Re: BigTerry] #1017446
06/21/11 08:05 PM
06/21/11 08:05 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
For sure, check your pressure. It should be in the 50-60 range. You can also check the relay in the PDC by swapping with one of the others. Most of the relays in the PDC are the same. See what happens. Look under the cab on the lh side behind the front fender liner. There is a connecter there that has the pump wiring in it. It may have loosened up. Had that happen once. If you end up replacing the pump, replace the relay too. If the relay is marginal, it will take out the pump due to lack of voltage. Another thing to watch out for is if it ran out of fuel. If it runs out of fuel, which also cools and lubes the pump, it will wipe it out.
Carl Kessel
Re: 96 Dodge Ram Won't Start [Re: 1970Dart3406] #1017447
06/24/11 12:46 PM
06/24/11 12:46 PM
St Charles MO
70Coronet500Vert Offline
St Charles MO
A 1996 Ram will die and not start if the battery is weak. My ran bad, tough to start, would die. I replaced the battery because it was 6 yrs old and it ran fine.
They are known for this.
No matter how responsible he may seem, never give your gun to a monkey!
1970 Coronet Vert
1972 Charger
1974 Satellite Sebring Plus Sundance
2001 Ram 4x4
2002 Intrepid
2006 300C
Re: 96 Dodge Ram Won't Start [Re: 70Coronet500Vert] #1017448
06/24/11 02:21 PM
06/24/11 02:21 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I doubt its the batt as he states it cranks but wont start.I agree swap the relays.But if sounds like the pump may be bad.They will usually start on ether though.What pump did you replace it with?I hope not Airtex.We used Bosch or factory at the shop.Then again I did have a couple of new factory pumps that were bad right out of the box.Check the fuel pressure as stated.Rocky
Chrysler Firepower
