Re: 96 Dodge Ram Won't Start
[Re: BigTerry]
#1017446
06/21/11 08:05 PM
06/21/11 08:05 PM
Posts: 667 Los Osos, Ca
CKessel
Los Osos, Ca
For sure, check your pressure. It should be in the 50-60 range. You can also check the relay in the PDC by swapping with one of the others. Most of the relays in the PDC are the same. See what happens. Look under the cab on the lh side behind the front fender liner. There is a connecter there that has the pump wiring in it. It may have loosened up. Had that happen once. If you end up replacing the pump, replace the relay too. If the relay is marginal, it will take out the pump due to lack of voltage. Another thing to watch out for is if it ran out of fuel. If it runs out of fuel, which also cools and lubes the pump, it will wipe it out.
Carl Kessel
[Re: 1970Dart3406]
#1017447
06/24/11 12:46 PM
06/24/11 12:46 PM
Posts: 8,430 St Charles MO
70Coronet500Vert
St Charles MO
A 1996 Ram will die and not start if the battery is weak. My ran bad, tough to start, would die. I replaced the battery because it was 6 yrs old and it ran fine.
They are known for this.
No matter how responsible he may seem, never give your gun to a monkey! 1970 Coronet Vert 1972 Charger 1974 Satellite Sebring Plus Sundance 2001 Ram 4x4 2002 Intrepid 2006 300C
[Re: 70Coronet500Vert]
#1017448
06/24/11 02:21 PM
06/24/11 02:21 PM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
I doubt its the batt as he states it cranks but wont start.I agree swap the relays.But if sounds like the pump may be bad.They will usually start on ether though.What pump did you replace it with?I hope not Airtex.We used Bosch or factory at the shop.Then again I did have a couple of new factory pumps that were bad right out of the box.Check the fuel pressure as stated.Rocky
Chrysler Firepower
