Internal balancein 360 #1010281
06/09/11 11:17 PM
06/09/11 11:17 PM
Kalispell Mt.
HotRodDave Offline OP
Kalispell Mt.
Can a 360 internally balance if you use a light weight rod like a SCAT I beam and a piston that is a little lighter like a KB107 can it be internally balanced with no mallory?
Re: Internal balancein 360 [Re: HotRodDave] #1010282
06/09/11 11:26 PM
06/09/11 11:26 PM
Mid Missouri
E
ETASPEN Offline
ETASPEN  Offline
E
Mid Missouri
I don't know for a fact, but I did a similar build with a light forged Wiseco flat top piston, scat rod (factory cast crank), and was told it could not be done without mallory. It did ext. balance fine.
Re: Internal balancein 360 [Re: HotRodDave] #1010283
06/09/11 11:50 PM
06/09/11 11:50 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
I don't believe so, closest I have seen is a 360 I had that had 6.625" Aluminium rods with a ultra lightened flat top venolia piston with a thin wall wrist pin. Piston and pin weighed around 440-460 grams. Whomever balanced the assembly welded extra material to the ends of the counterweights. I don't see it happening with off the shelf parts, you would need atleast a couple slugs of mallory metal.
Alan Jones
Re: Internal balancein 360 [Re: HotRodDave] #1010284
06/10/11 12:41 AM
06/10/11 12:41 AM
Delray beach, Florida
P
Performance Only Offline
P
the 107 isn't light enough to get you there. to internally balance you'll need to be around 1475-1525 grams on the bobweight. the lightest i've typically seen with light shelf parts is around 1725. remember that your dealing with cranks that typically already have 1" holes 1 1/2 inches deep in the front and rear ctwts. welding them up like one might do with a steel crank isn't recommended on a cast crank.
machine shop owner and engine builder
Re: Internal balancein 360 [Re: Performance Only] #1010285
06/10/11 11:40 PM
06/10/11 11:40 PM
Bristol, Va
fasteddie Offline
fasteddie  Offline
Bristol, Va
The 360 in the Dart is internally balanced. We used a stock cast crank, flat top SRP pistons and Scat I beams. I don't know the weights but I do know the machine shop had to drill some holes in the crank to balance it. No Mallory metal needed.
2003 Bristol Dragway Sportsman Champion
2016 Bristol Dragway Power Hour Champion
Re: Internal balancein 360 [Re: fasteddie] #1010286
06/11/11 12:39 AM
06/11/11 12:39 AM
P
P
so you didn't have a damper or flexplate on it when it was balanced? i've used that same combo of parts and the bobweight was in the mid 1700's. i'd love to know what the casting # of that crank was in your combo that still needed to be lightened. very very unusual.
Re: Internal balancein 360 [Re: fasteddie] #1010287
06/11/11 08:43 AM
06/11/11 08:43 AM
San Diego
formula S Offline
formula S  Offline
San Diego
Could you post the balance sheet I'd like to see the weights of the components used in your build
Re: Internal balancein 360 [Re: HotRodDave] #1010288
06/11/11 10:16 AM
06/11/11 10:16 AM
Lehigh Acres, Florida
rickstershemi Offline
Our 360/408 has Scat cast 4" crank, Scat I-beams & Icon flat tops (not light) and took one very small slug.
Rickster
