Internal balancein 360
#1010281
06/09/11 11:17 PM
06/09/11 11:17 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Can a 360 internally balance if you use a light weight rod like a SCAT I beam and a piston that is a little lighter like a KB107 can it be internally balanced with no mallory?
Re: Internal balancein 360
[Re: HotRodDave]
#1010283
06/09/11 11:50 PM
06/09/11 11:50 PM
Posts: 6,136 Melbourne , Australia
LA360
I don't believe so, closest I have seen is a 360 I had that had 6.625" Aluminium rods with a ultra lightened flat top venolia piston with a thin wall wrist pin. Piston and pin weighed around 440-460 grams. Whomever balanced the assembly welded extra material to the ends of the counterweights. I don't see it happening with off the shelf parts, you would need atleast a couple slugs of mallory metal.
Alan Jones
[Re: Performance Only]
#1010285
06/10/11 11:40 PM
06/10/11 11:40 PM
Posts: 549 Bristol, Va
fasteddie
Bristol, Va
The 360 in the Dart is internally balanced. We used a stock cast crank, flat top SRP pistons and Scat I beams. I don't know the weights but I do know the machine shop had to drill some holes in the crank to balance it. No Mallory metal needed.
2003 Bristol Dragway Sportsman Champion
2016 Bristol Dragway Power Hour Champion
[Re: fasteddie]
#1010287
06/11/11 08:43 AM
06/11/11 08:43 AM
Posts: 660 San Diego
formula S
San Diego
Could you post the balance sheet I'd like to see the weights of the components used in your build
[Re: HotRodDave]
#1010288
06/11/11 10:16 AM
06/11/11 10:16 AM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
Our 360/408 has Scat cast 4" crank, Scat I-beams & Icon flat tops (not light) and took one very small slug.
Rickster
