Re: HONING PLATE!!!
[Re: maximum entropy]
#1007874
06/06/11 01:26 PM
06/06/11 01:26 PM
Posts: 2,924 A shed in England
Tig
A shed in England
Did you measure it with no plate or head installed?
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
Re: HONING PLATE!!!
[Re: perfmachst]
#1007879
06/08/11 06:21 PM
06/08/11 06:21 PM
Posts: 5,080 organ
maximum entropy
organ
funny you should ask. i measured immediately, and then the next day (both ways- head and deck plate). i had other things going on. it wasn't my plan. everything measured the same both times.
Re: HONING PLATE!!!
[Re: Scotts71chall]
#1007881
06/08/11 09:01 PM
06/08/11 09:01 PM
Posts: 5,080 organ
maximum entropy
organ
yes. use the same gasket you're going to assemble the engine with. if you're using head bolts (not studs), washers and/or spacers need to be used to assure the same thread engagement as the head you'll be using. details details.
