HONING PLATE!!! #1007873
06/06/11 12:31 PM
06/06/11 12:31 PM
organ
maximum entropy Offline OP
organ
i got one of performance only's honing plates for bb mopar. i torqued an edelbrock head to a bare block (bored, not honed yet), and measured cylinder distortion from underneath (main caps torqued in place). i removed the head and torqued dan's plate, and the cylinders measured exactly the same as they did with the edelbrock head. good job dan!!!!
Re: HONING PLATE!!! [Re: maximum entropy] #1007874
06/06/11 01:26 PM
06/06/11 01:26 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Did you measure it with no plate or head installed?
Re: HONING PLATE!!! [Re: Tig] #1007875
06/06/11 01:39 PM
06/06/11 01:39 PM
organ
organ
yes. it was bored with no plate. they are darn near perfect with nothing torqued to the block. the distortion varied significantly from cylinder to cylinder. a couple of 'em were almost .002 out. the distortion is worst at the top of the cylinders, adjacent to each head bolt hole.
Re: HONING PLATE!!! [Re: maximum entropy] #1007876
06/06/11 11:25 PM
06/06/11 11:25 PM
Delray beach, Florida
P
Performance Only Offline
P
thank you for the feedback. i really appreciate it.
i think you've just confirmed our claims of our torque plates accurately reproducing the distortion the cylinder head produces. thank you for taking the time not only to test it, but to post the results also.
machine shop owner and engine builder
Re: HONING PLATE!!! [Re: Performance Only] #1007877
06/08/11 04:32 PM
06/08/11 04:32 PM
organ
organ
i was going to give a bump... oops. just did.
Re: HONING PLATE!!! [Re: maximum entropy] #1007878
06/08/11 04:59 PM
06/08/11 04:59 PM
renton , washington
P
perfmachst Offline
perfmachst  Offline
P
renton , washington
hi, question, how long was it bolted down untill you measured the bores?? hours or minutes??
Re: HONING PLATE!!! [Re: perfmachst] #1007879
06/08/11 06:21 PM
06/08/11 06:21 PM
organ
organ
funny you should ask. i measured immediately, and then the next day (both ways- head and deck plate). i had other things going on. it wasn't my plan. everything measured the same both times.
Re: HONING PLATE!!! [Re: maximum entropy] #1007880
06/08/11 07:27 PM
06/08/11 07:27 PM
WI.
Scotts71chall Offline
WI.
Do you use a head gasket when using the plate?
Is it necessary?
Re: HONING PLATE!!! [Re: Scotts71chall] #1007881
06/08/11 09:01 PM
06/08/11 09:01 PM
organ
organ
yes. use the same gasket you're going to assemble the engine with. if you're using head bolts (not studs), washers and/or spacers need to be used to assure the same thread engagement as the head you'll be using. details details.
