2004 Jeep Liberty's A/C - how easy to fix? #1004194
05/31/11 11:07 PM
05/31/11 11:07 PM
E.Amherst, NY
69RR Offline OP
69RR  Offline OP
E.Amherst, NY
My girlfriend's Jeep Liberty's (2004) a/c went out before the hot weather started. It worked last year. Could be as simple as needing a freon charge? or is it more complex? I've never worked on air conditioning before. Any help would be appreciated,
Dean Got my hands on the wheel, foot to the pedal, gonna drive this car till the tires turn to metal - gonna sleep when I'm dead and laugh at the devil..
Re: 2004 Jeep Liberty's A/C - how easy to fix? [Re: 69RR] #1004195
05/31/11 11:45 PM
05/31/11 11:45 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
if it went out suddenly, i'd suspect a leak. a good a/c shop will check it for free. you could always do it yourself, with an a/c leak detector kit. comes with a can, filler and a uv light to find the leak.
Re: 2004 Jeep Liberty's A/C - how easy to fix? [Re: 69RR] #1004196
06/01/11 12:14 AM
06/01/11 12:14 AM
Toronto, Ontario, Canada
plazomat Offline
plazomat  Offline
What are the symptoms?
My 2002 liberty's AC went, it was a slipping clutch on the AC compressor.
$20 got me a new clutch friction cover, 10 mins work, and been good for 2 years.
Mechanic wanted $900 to replace compressor, drier etc....so diagnose it before they rape you...I think you can pick up compressor, filter and drier kit on the bay for around $300.
Plaz
Re: 2004 Jeep Liberty's A/C - how easy to fix? [Re: plazomat] #1004197
06/01/11 09:04 AM
06/01/11 09:04 AM
E.Amherst, NY
69RR Offline OP
69RR  Offline OP
E.Amherst, NY
Hey thanks for the advice. I'll look into both suggestions...
Re: 2004 Jeep Liberty's A/C - how easy to fix? [Re: 69RR] #1004198
06/01/11 09:13 AM
06/01/11 09:13 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
We used to check for pressure in them first.Then we evacked the system and pulled a vacuum.If it held we charged and checked for leaks.If they leaked we re evaced the system as its illegal to fill a system that has a leak.thanks feds.There are a few sealrs that will seal small leaks and do a great job.Rocky
Chrysler Firepower
