Re: Fan clutch for 68 RR
[Re: Scatransit]
#1000723
05/29/11 02:26 PM
05/29/11 02:26 PM
Posts: 5,449 So Cal
Sinitro
So Cal
I tried the 2765, but the flange diameter was too small. It did not support the bolts properly. The 1705 non-thermal is what I went with, it's closer to o.e. height at 1 1/2" vs. 1 1/4" and the flange diameter is closer to o.e. - if not exact. Although the Hayden units have slots instead of holes, the 1705 still is a better fit IMO. You can look through their catalog online and see the specs for all of their clutches. It's also inexpensive, I think I paid about $30 IIRC.
http://www.haydenauto.com/upload/HaydenAuto/Documents/Cat_Hayden/2007-hayden-fan-clutch.pdf
Another alternative is to search for a TRW FC28. The FC28 was an Mopar OE replacement, short height 2.75", closed 4-bolt hub...
Just my $0.02.. ![](/ubbthreads/images/graemlins/wink.gif)
[Re: Sinitro]
#1000724
05/29/11 07:59 PM
05/29/11 07:59 PM
Posts: 426 Mid-Atlantic
Scatransit
Mid-Atlantic
I'm pretty sure the height should be 1.25" not 2.75" ?? I'm not 100%, but I believe the 070 clutch - or one similar dimensionally - was used with all 26" radiator applications (not sure about A/C cars) where a Hemi, A12 Pkg, 4-speed 440, or 383 Axle Package was installed. And the height measurement was 1.25"...Someone else may want to chime in on this? ![](/ubbthreads/images/graemlins/beer.gif)
[oo]======[oo]
[Re: Scatransit]
#1000725
05/29/11 10:15 PM
05/29/11 10:15 PM
Posts: 5,449 So Cal
Sinitro
So Cal
The 2.75" height spec includes the total assembly, set it on a flat surface and measure its total height including hub and clutch assembly.
[Re: Sinitro]
#1000726
05/29/11 11:24 PM
05/29/11 11:24 PM
Scatransit
Mid-Atlantic
I did not realize you were using "overall height"... I thought you were using "fan height"... It makes more sense now.
[oo]======[oo]
