You definitely need a blanket or a shield.Ask Don Garlits 1/2 of his foot gone. If you use a trans brake start your burnout in 2nd gear then to 3rd. as you start moving out of the water and the tires move to dry surface let off of the throttle. don't accelerate in first let off and hammer it again.
