Re: Burnouts,exploding trannys and lauch proceedure
[Re: RemCharger]
#987198
05/06/11 04:59 PM
05/06/11 04:59 PM
Posts: 5,080 organ
maximum entropy
organ
Leave in manual low?
No, put the shifter in second then hit the pedal pretty good... its going to start out in low then it'll shift on its own pretty quick then get the revs up a bit more and then shift into drive... let it burn forward a few feet then back off the pedal... pull to the line... you can manually shift it if you want or put it in drive... your choice
I don't agree with this(Respectfully) because you will be starting out against the sprag alone. Put in low and you will apply the low band, therefore helping the sprag hold all of the torque you are putting to it , trying to get the tires lit. Remember, this is not a mv body. Please explain if I'm off base here.
i'm with remcharger on this. anything you can do to protect the sprag should be implemented. manual low may seem redundant if it jumps right into second, but weird things happen. a lot of stuff blows up in the burnout box. i ran an automatic valve body for a long time, and i always started in manual low, whether in the burnout box, or on the track.
for what is the good life if not doing things thoughtfully?
Entire Thread
shoebox
05/06/11 07:23 PM
moparacer
05/06/11 07:26 PM
shoebox
05/06/11 07:42 PM
sam64
05/06/11 07:57 PM
MR_P_BODY
05/06/11 08:03 PM
RemCharger
05/06/11 08:12 PM
moparacer
05/06/11 08:31 PM
maximum entropy
05/06/11 08:59 PM
kissmyaspen
05/06/11 09:23 PM
shoebox
05/06/11 10:00 PM
StealthWedge67
05/07/11 02:42 AM
John_Kunkel
05/07/11 10:08 PM
fishy340
05/07/11 11:08 PM
StealthWedge67
05/08/11 01:03 AM
Twostick
05/08/11 01:50 AM
Leon441
05/08/11 02:30 AM
Leon441
05/08/11 02:37 AM
Crizila
05/08/11 02:42 AM
savoyracer
05/09/11 05:52 AM
B G Racing
05/09/11 10:13 AM
shoebox
05/10/11 02:40 PM
Mopar-Al
05/10/11 05:15 PM
Crizila
05/11/11 01:44 AM
Runner
05/11/11 01:58 AM
451 D*O*D*G*E
05/11/11 03:28 AM
Crizila
05/11/11 03:33 AM
A727Tflite
05/18/11 02:51 AM
RemCharger
05/06/11 08:00 PM
robnbird
05/08/11 05:30 AM
Den300
05/08/11 08:36 AM
FurryStump
05/08/11 02:51 PM
DragtimeDodge
05/09/11 01:55 AM
Crizila
05/09/11 03:49 AM
robnbird
05/09/11 04:18 AM
dOc !
05/06/11 08:37 PM
cbarracuda
05/07/11 03:32 AM
dOc !
05/07/11 04:42 AM
Crizila
05/07/11 05:01 AM
cbarracuda
05/07/11 05:17 AM
CrazyD
05/07/11 01:59 PM
moparmxz
05/07/11 02:19 PM
MR_P_BODY
05/07/11 02:29 PM
robnbird
05/08/11 05:16 AM
