Yes I love turbos for the drivability. My cam is only 224*@.050" and I made 581 to the tires at 5000 RPM because the turbo was choked on the turbine. When it flashed the converter it would jump to 700 ft lbs of torque. With the EFI the drivability is something else. Oh and the truck only need 3.23 gears to run in the 11s. Turbos rock.
11.67@118 1.88 60' with only 7-8 lbs of boost. Turbocharged, megasquirted, 407 BB, 440 source heads, roller cam, 9:1 comp. http://s292.photobucket.com/albums/mm14/beansgracie
