Any dyno tuner should be able to help you with the timing. Tune for best torque to make the engine live. Don't add timing to make HP, add boost. Always tune for best torque at any positive load points. Don't limit yourself with a pre-determined boost number. You will kill a motor faster with timing than with boost.
"use it 'till it breaks, replace as needed"
