Ok here is how I rigged it up with my alky injection I just put on this past week.
First pic shows out of the front of the valve covers and don't forget to make sure they are baffled or it will suck oil when the engine is running.
Second pic is the breather setup I use to catch the moisture from the alky. I mounted the pump under the fender up front to save on space under the hood. The breather tube runs down through the hole where the battery tray was originally. As you can see the clear tubing is completely fogged up with moisture and water droplets with it running so its definatley pulling it out. Better off there then in the pan!
Last pic is the pump under the fender.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
