Re: Voltage drops in a 12v 1954 dodge
[Re: mafo]
#972454
04/15/11 06:17 PM
04/15/11 06:17 PM
Posts: 10,619 Freeport IL USA
poorboy
Freeport IL USA
Gene, I used all the old stuff expect the motor itself, the dakota motor was almost a bolt in,you have to make a new sector arm to fit the motor since the original one doesn t fit the new motor, I guess you could modify the old one too..., wiring was a bit tricky if you want to use both speeds
Ah, see that's the problem, I'm dealing with wipers on my truck. the original wiper motor had the motor in the center with a transmission on each side to operate each wiper, there is no center arm. My 50, my 54, and my son's 55 all had the dual transmission wiper motors. My 48 Plymouth had a vacuume wiper, but it has the center arm, maybe I can modify the arm and connect it to my Dakota wiper motor. I already have the Dakota wiring harness. That will make life a lot easier. Gene
