I have found that the pin is just for glass tilt adjustment for a tighter fit to the door frame .
That's what my buddy is saying; that the pin pushes up to tilt the vent frame for a tighter fit to the door frame, but it can't do that unless there is something to give it upwards pressure right? without any sort of bushing, the vent frame is free to float on the pin with no upwards pressure.
I'm convinced that there was no such bushing, but without one, you are relying on the two upper bolts to hold the vent frame in position, correct?
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
