Is it better to have a winch or a drivers escape side door to get your car in and out of the trailer? What do most of you guys do to get your car in and out? Im trying to decide what to get for my truck which may be a little wider than a car.
I use a 4500 lb super winch with a 30 ft. cable, I load the car to the right side of the trailer so I can walk down the left side to watch the front and the right inner fender on the trailer as I load it I have used a 2500 lb winch in the past on another trailer and it would get real slow when the front and rear tires where on the ramp and on the dove tail at the same time The 4500 lb winch will pull the car in with it in park on dirt , Done that accidentily several times
But Cab.... is that reaching in a open window to steer
it.... when I would winch my car in I would have
to steer it by moving the tires... not bad on my car
but if the car is heavy you would most likely need
to do it rolling
