If you had the same issue with the old motor/trans combo, then take a look at things that have remained in the driveline..same trans mount, balancer, pulleys, I know some of those things don't swap over to what you have now but of those things that do, have a look. Make sure Distributor shaft isn't bent, giving you erratic fire out f the cap.
