I thought about doing a mopar green bearing housing end on the 9.25 rear. But, you still have the issue with no available spools. We went with a Dana 60 spools 35 spline axles and if you need to use the exiter ring they were available on 93 3/4 ton HD dodge trucks. It think a drill to drill a hole for the pickup. A spool for a thick gear, the ring and thin gear will bolt together.
Career best 8.02 @ 169 at 3050# and 10" tires small block power.
