I've seen guys just plug the holes for the PS hoses on the rack. My idea for the MII was just to get a manual rack in there. You will need the correct width at the inner tie rod pivots to help correct/prevent bumpsteer. If you draw an imaginary line through the upper and lower control arm bushings, the inner tie rod pivot should fall on that line.
