Good Post Im having to offset the bores of my X block. Im having to shift to the front about .050 to correct wall thickness.There's also some good reading at speedtalk.com.
I dont understand... why not just sleeve it
I knew if you wanted a big bore they did it but to
correct for core shift or a broken cylinder I would
have thought just sleeving it would do
