The change affects the clock position of that piston vs. its crank throw.
Assuming the pin eye as the focal point, an RB has a radius of 1/2 stroke + rod = 8.635", = 54.255" circumference circle, = .151" per degree.
That makes any re-location almost invisible, like .030" is 1/5th of a degree.
Someone check my math, please?
Boffin Emeritus
