if set @ 800 fluctuates between 780 - 810 normal ?
Actually yes as I forgot that you have a cam. It MAY need a higher idle speed to stabilize. EDIT after (re) reading I dont think it's a dist prob. I would set the (initial)timing via the vac gauge method then shorten the slots to get 36-38 total then play w the springs (more on that later) then dial in the vac adv (more on that later). You will need to find the idle speed for that cam that is stable (maybe higher than 800) and I am not a 6 pack guy but they (the carbs) MAY or may not need mods for a wild cam
