It only takes about a pint to lube the engine. I'd think if they spun bearings on a fresh build they screwed something up. Not primed, not properly lubed on assembly or maybe the wrong assembly lube was used. Of course there could have been improper clearances or other mechanical faults.
Even a quart low on a stationary engine shouldn't be a problem.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
