There's only one more variable to be worried about: Does it have enough stroke?
It has MORE than enough throw. In fact, you have to install a clutch pedal stop to limit travel.
I drilled a hole in the floor (in line with the clutch pedal arm, of course), welded a 5/8" nut to it, and threaded in a 5/8 bolt and double nutted it at the correct throw distance. It's adjustable that way.
