Did you have any problems bleeding it out since the bleeder is on the bottom?
You notice that the one I gave you the link to has the bleeder screw on top. That's the correct no.
Mine with the bleeder on the bottom wasn't a problem though. There's really no chamber for air to really get trapped.
The beauty about this 20 dollar gem is even if you run an old style big clunky starter, it will fit.
