Who is using the Edelbrock Super Victor Max Wedge intake with Edelbrock Victor Max Wedge cylinder heads I’m playing with the idea of taking off my X ram intake next season and running a single plane. My engine builder told me I could use one of his racing carburetors so I’d only have to pay for the intake.
Here is my build, 505 pump gas motor with 10.75:1 compression.
Custom ground Bullet roller, 640 lift
Hand ported MW Victor heads with 1.6 T&D rockers.
MW Rick Allison cross ram.
835 Holley carbs done by Ken Jones.
2”TTi’s
Motor made 730hp @ 5700 and 730lbs torque @ 4500 rpm on Mobil 93oct pump gas
I have the SV on Max Wedge Victors. Here is a link to my build. Made 768hp @ 6500 and 683 ft lb @ 5000. I re-used my mild solid roller in this motor, .630 lift and 264/268 @ .050 which is .700 with the 1.7 T&D's.
505 motor build
Dyno numbers
Best to date is a 9.92 @ 135 in my 3550 lb coronet.
Haven't changed anything since the dyno session, same jetting and timing.
