Here is my build, 505 pump gas motor with 10.75:1 compression.
Motor made 730hp @ 5700 and 730lbs torque @ 4500 rpm on Mobil 93oct pump gas
Those are nice numbers. What ET/mph and weight is the car running?
If you are running a factory cross ram intake, the Super Victor will be a big improvement and allow more rpm.
1993 Daytona, 5.50 at 130mph (1/8) 1.19 sixty ft (PG). Link to 572 B1 - Part 1
