we will be able to remove the access plates for any servicing as we modify the boot floor to have an access panel.
Also, I am adding two additional tanks for sufficient capacity. They will fit inside the rear quarters and extent as far toward the centre of the trunk as the trunk lid lip. I'm adding another gas cap to the RH quarter. Each gas cap will fill each side tank, which will then feed into the main tank. Each quarter tank will be fabricated from aluminium with internal bladders (made by ATL in NJ). Vents from all 3 tanks will run into charcoal canister to stop any fumes.
Engine will run on both E85 & ordinary petrol. primary pump is speed controlled and second is staged.
