thanks, yep I checked with Aeromotive and they said fine with E85. The technical spec's that come with the pumps also says that they're ok with Alcohol, they're then rated for less power as you need more fuel to deliver the same power -hence 2 pumps to be safe. Pump #1 runs via the speed controller and Pump #2 will be rpm/boost referenced via the ECU when we get that sorted.
Just my on the stainless steel bolts. I am not a real fan of stainless bolts, simply due to the fact, if they are dropped in a hard to access area(like maybe into the fuel tank, engine,etc) a magnet will not pick them up for you. DAMHIK!!! I realize they don't rust, corrode as much, etc. Maybe I have just been too 'fumble fingered' too many times.
If you like drag racing, support your local track.
