Here's what it looks like if you swap the core suport and keep the correct year grill('85) If I remember correctly you can remove the Intercooler (spot welds) from the newer core supt and re-attach them to the original one. Here's a quick mod list if you bring over teh later parts. -Front springs -complete wiring harness (if a stick you will have to moven the bulk head to the late(92) position on teh fire wall to allow for the clutch master cyl -change to later wiper motor and re-position monting holes -brake booster/master cyl swap -re-drill frame rails to locate later trans cross member swap fuel tank and plumbing Here's what yo u may want to consider just unplug the Anti-loc modual and leave it that way (dont have to swap over the rear controll valve) -Auto Trans is different from Gas to Deisel ( beefier parts on the inside)
any q's PM me and I'll answer best I can
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
