i was thinking it would be helpfull to have the groove spiral to feed the material out instead of clogging.
I cut mine at an angle for just that purpose. But I stilled pulled the cam in and out a few times wiped it clean , so I wouldnt get any sharp pieces grinding away at the bearing.
Im not sure but I think I offered to lend it to you at the beginning of the season. Or someone up that way.
They are easy enough to make with any old cam. I used a hack saw so my slot is rather thin but worked great. mike
yes you did offer and i will be more carefull this time.
