Talked to an engineer at Eagle, they do cut thier rods to 1.007" about .007" under. The reason he gave me was to let the oil escape the bearing faster reducing heat. Better for the rod bearings.
??? What do you think. If you want the oil to leave the bearing faster, that could be done by increasing the rod bearing clearance to the crank???
