Using the dremel,make the slots in the housing.
Also it may be necessary to make the hole in the housing larger.
ALWAYS GRIND LITTLE AT A TIME AND TEST FIT OFTEN!
One shot deal to make this work and if the holes are too big the housing is junk.
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
