This example show some corrosion around the socket.Not bad--but enough to feeback into the curcuit and pop fuses.Moisture got in from the dry rotted lense gasket.
Note how corroded the housing body is from being out in the open from the elements.That alone can cause a bad ground.you can see where I cleaned up around the mounting screws but that did not help.
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
