GTXKen....diagram is exactly what I'm looking for (not sure of the wire colors tho).
My plan is to get power off the starter relay stud....2 fused 10 guage wires.
I'll be running 4 halogens.
My headlights are very bright as is, but I want to take the load off the headlight switch.
I have already re-wired with 10 guage all the wiring from the alternator, thru the dash, back out to starter relay stud with a 14 ga. fusible link. I have eliminated all the connectors (5 ?)in between...so I have very little voltage loss to the battery. Headlights scream at idle !
69Charger.....your pic looks scary ! Should have some fuses on there !
