I just installed a Painless harness in my 68 Charger would it be necessary to intall relay's. My biggest concern is the actuall headlights. On my 69 Roadrunner I installed GE Halogen lamps(the only thing I could find). I hated them, they shined a straight beam of light and I couldn't see anything. I hated driving the car at night. Is there anything available other then Halogens lamps. I have seen the newer style with the replacement bulbs like on newer cars but haven't seen anyone use them on the older cars or seen any feed back on them. Do they pull more amperage then a standard headlight.
I also done away with the amp meter. I used all new Autometer gauges including volt gauge, with the painless harness.
